Re: IH H Model with Hydralics
Posted by Hydraulic Rebuild Technit on March 11, 2004 at 16:44:49 from (63.166.167.187):
In Reply to: IH H Model with Hydralics posted by Pat Irestone on March 11, 2004 at 11:32:09:
If your hydraulic cylinder is leaking where the cap connects to the cylinder body itself and there are four LONG bolts that hold the unit together, then my assumption would be that the
O-ring in the cap which seals the main body of the cylinder is leaking. First, check the torque on all 4 bolts they should be exactly the same. If not, torque them all to about 45 lbs. test the cylinder. If it is still leaking, then you may want to consider replacing the o-ring. BE DARN SURE TO KEEP EVERYTHING PRISTINE CLEAN!!!!!! Failing to keep everything clean will damage or will shorten the life of your hydraulic system. If you don't have the tools to replace the o-ring and keep everything clean, a new cylinder from Tractor Supply shouldn't be more than 30-40 dollars. Sorry to be so long winded. Kippster
Post A Followup
: Re: Re: IH H Model with Hydralics
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
