Re: Rough running M farmall Day 2
Posted by CNKS on March 18, 2004 at 19:09:45 from (207.178.96.214):
In Reply to: Rough running M farmall Day 2 posted by dave w on March 18, 2004 at 18:26:46:
You have a kerosene head. i'm surprised your compression is that good -- justin, on your web page, you list the C248 distillate compression as 96, is kerosene any different? Dave-- I'm kind of grasping at straws -- You have a distributer, that is unusual for a 41 -- do you have the point gap set at 0.020, I don't know why that would cause only one cylinder not to fire. You can't have a bad valve with that kind of compression. Have you adjusted the valves? -- 0.017 hot. It almost sounds as if the number 2 exhaust valve is not opening, but I really don't the symptoms for that problem, perhaps not enough air, and the fuel does not ignite. Anyway, it won't hurt to check your valve clearance.
Post a Followup
: Re: Re: Rough running M farmall Day 2
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
