Re: Rough running M farmall Day 2
Posted by lee on March 19, 2004 at 06:58:56 from (24.24.92.235):
In Reply to: Rough running M farmall Day 2 posted by dave w on March 18, 2004 at 18:26:46:
If you really think you have ignition I would go along with Wayne maybe a worn cam lobe. Compression check may not reveal. Cylinder may be filling at slow cranking speed but not at running speed. You could try a dynamic compression check (see below). Or pull the valve cover and measure the valve lift on good and bad cylinders. Inspect the valve rockers etc., closely. You can also look for intake manifold leak or crack at #2.
http://www.misterfixit.com/dyncompr.htm
Post a Followup
: Re: Re: Rough running M farmall Day 2
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
