Re: remote hyd pressure on 560
Posted by Joe Evans on March 22, 2004 at 06:49:50 from (209.41.233.105):
In Reply to: remote hyd pressure on 560 posted by Chris Brown on March 21, 2004 at 19:19:14:
Chris: I am trying to correct some hydraulic problems with a 460. I am a rookie at these systems, but disassembling the control/relief block on the 460 this past weekend I think qualifies me to help you out a little. The relief valve is located in a "block". This block is under the remote and fast hitch spool valves-the ones where the control lever attach. The block is mounted the the left-side pedestal casting that holds up the control valves and dash. Remove the sheetmetal piece that the brake set pull rod attaches to, and you will see all of this. From what I have seen on Saturday, it appears the relief valve is non-adjustable. There is no screw type or threaded adjuster. Perhaps a stiffer relief valve spring is avaiable. This will allow the system to generate a higher pressure that you need before the pressure is relieved or 'dumped'. Perhaps the relief spring can be shimmed, but from what I saw, this doesn't seem to feasible. I would caution anyone in attempting to jack up hydraulic system pressures. It could be that the existing relief valve spring is sacked out--weaker than factory specs and dumping the pressure too early. I think the manual spells out a correct length for the spring and a pounds of resistance to compresss the spring a certain distance. I see in your post that you checked the pressures so a weak relief spring is not the case. Another option is changing the lift cylinders on your loader to ones with larger bores. More piston area = more force.
Home
| Forums
Today's Featured Article -
A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
