Re: What to check on a Farmall H?
Posted by KURT (mi) on March 24, 2004 at 15:52:46 from (67.72.196.134):
In Reply to: What to check on a Farmall H? posted by SAm in NS on March 24, 2004 at 15:26:07:
I had an H a year ago. I checked the following things, Check engine compression should be better than 85 Psi per cylinder. Make sure it runs and drives good. make sure the trans mission shifts in all gears, 1 reverse and 5 forward....remember that 5th gear is 15mph, a little scary on a farmall H with no seat belts. Look for leaks in the engine and trans, start it cold, look for welds in the block and trans check fluid levels ask questions like, when was the last time engine oil was changed, check the tire condition too. Let it run for a while and restart hot. This should help.
Post a Followup
: Re: Re: What to check on a Farmall H?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
