Re: Re: What to check on a Farmall H?
Posted by TOMMY H (FL) on March 24, 2004 at 18:34:03 from (65.140.18.161):
In Reply to: Re: What to check on a Farmall H? posted by John (AZ) on March 24, 2004 at 17:02:42:
If the block has been welded, dont panic and walk away. Usually its no big deal. First check and see if its leaking currently, while running. See if its been recently cleaned. Indicating that the owner may be trying to conceal a leak that takes a while to appear. But a welded block is typical. If there is no oil i nthe water, and no water in the oil, its fine!
Manifolds, mufflers, seats...all inexpensive parts that are easy to fix if broken. IF these parts are in rough shape, ask for a lower price!
If the Transmision makes noise, loud rackety noise..id be concerend, cause while parts arent difficult to locate, they're a real pain to install.
Post a Followup
: Re: Re: Re: What to check on a Farmall H?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
