Re: Check Location on M Belly Pump
Posted by Ed Topel on March 30, 2004 at 21:00:25 from (205.188.116.213):
In Reply to: Check Location on M Belly Pump posted by GB on March 30, 2004 at 18:14:42:
Posted by Lynn (Ia) on April 23, 1999 at 18:32:51:
In Reply to: Re: Re: Re: Hydraulics on '47 M posted by Bob on April 23, 1999 at 07:26:52:
Just got back from the barn. My dipstick measures 11&1/4 inches from the top of the filler tube. The full mark is located 2" up from the bottom. This would mean that full is 9&1/4" down from the top of the filler tube. Suggest using a heavy guage wire (like #9) & bending a loop at the top & notching it at the full mark. You could then hang it on the tractor for fast checks. Hope this helps. Lynn
I saved this post from quite a while ago, hope it helps.I used a piece of wire and brazed it to a fender washer just big enough that it wouldn't fall down the pipe but I can still screw the cap on.Ed
Post a Followup
: Re: Re: Check Location on M Belly Pump
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
