Re: early M PTO seal
Posted by Bill on April 02, 2004 at 14:30:20 from (216.202.120.12):
In Reply to: early M PTO seal posted by MM on April 02, 2004 at 11:39:22:
It's pretty easy. Make sure the rear end fluid is below the level of the PTO housing. Unbolt the housing from the tractor and either drive or pull the current seal from the housing. The new one I got was about half as thick, but seems to work fine. I've seen other posts discuss using two new style seals. Start the seal carefully, rubber toward the front of the tractor and tap in with a plastic hammer. Good luck.
Post a Followup
: Re: Re: early M PTO seal
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
