Re: Farmall450 Power Steering Problem,Also TA Ques
Posted by Dan on April 10, 2004 at 21:32:10 from (12.160.175.143):
In Reply to: Farmall450 Power Steering Problem,Also TA Question posted by Harlen Larson on April 10, 2004 at 20:08:52:
It takes more power to steer when standing still so perhaps the steering is a it weak or hydraulics a little weak. The TA is ment to be shifted on the go. It enabeles you to shift down when needed for a tough spot or to slow down, then go back to regular speed when it gets easier. It should be shifted quickly and should not be used to slow the tractor as when approaching a stop sign on the road. It will not hold you back going down as hill either. I think the ta is great on my SMTA. If used properly it will last a long time,if not it will fail quickly.
Post a Followup
: Re: Re: Farmall450 Power Steering Problem,Also TA Ques
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
