Re: IH Farmall 400
Posted by sod on April 12, 2004 at 11:12:13 from (209.206.151.92):
In Reply to: IH Farmall 400 posted by Chris Jensen on April 12, 2004 at 10:39:10:
Get yourself an operators manual. They are cheap.
I think it's the same for both the 400 and the 450. About 15 gallons (U.S.).
Drain the tranny and diff. (plugs on the bottom)
there is also a plug towards the middle of the tractor. Not much will come out but it's good to get rid of any source of contamination. Loosen the belt pulley cover also and let the water out of there also.
Let it drain a LONG time, then fill it through the triangular shaped plate on the top of the housing by the shifter. (right about where your right foot would rest) Use trademark HY-TRAN to fill it with. Be prepared to spend about a hundred bucks to change it out, but it's worth it to your torque amplifier.
good luck
sod
Post a Followup
: Re: Re: IH Farmall 400
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
