Re: F-20 clutch houseing removel
Posted by John in NE on April 28, 2004 at 22:45:17 from (170.54.59.160):
In Reply to: F-20 clutch houseing removel posted by Paul G. in Mn on April 28, 2004 at 18:47:19:
I went through this last winter on a '36 F20 I'm working on for a friend. It's tough but do able.I rented a three legged puller from a rental store.They called it an axle puller.Bolt the puller to the flywheel and pull like mad.The one I rented had a Tee handle that you acually beat around with a hammer.It worked great,the biggest problem I had was putting it back together.I had to pull the motor out of the frame and I built a stand so the crankshaft sat vertically to the floor.There is not alot of room to get the flywheel back into the bell housing and get everything lined up.You will need a big hammer and several blocks of wood to get it back together.I got pretty rough with it,and didn't seem to hurt anything.I felt like I had really accomplished something when I was done.John.
Post a Followup
: Re: Re: F-20 clutch houseing removel
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
