Farmall Tractors Discussion Board
Carter UT carb Kit for Super C
Posted by justin on October 25, 1999 at 20:05:58 from (209.83.211.105):
I know that parts for the carter carbs are hard to come by, but I was hoping that someone had a possible source for a carb kit for one of these carbs, or atleast a source for gaskets, needle and seat.. I did see that Branson Enterprises has a carb kit listed for a massey that uses the Carter UT, but the question is will it work.. Plan on calling on the specs, but maybe someone out there has had some experience with this problem.. BTW.. I want to keep this carb, not replace it with a Zenith..
thanks..
Post a Followup
: Re: Carter UT carb Kit for Super C
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
