Re: Re: IH-504 Disc Brake Assembly Problem
Posted by rcwilbur on May 06, 2004 at 05:32:16 from (12.2.142.7):
In Reply to: Re: IH-504 Disc Brake Assembly Problem posted by Scott on May 05, 2004 at 19:41:27:
I just replaced the brake pads in my 504. I would recommend that you knock out the center cap in the brake housing cover, as Scott suggested. I had to hit it pretty hard to get it to come out, but once it is out you will easily be able to align the outer brake with the spline. Once everything is installed the center cap can be tapped back in with a hammer.
Good Luck. Carl
Post a Followup
: Re: Re: Re: IH-504 Disc Brake Assembly Problem
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
