Re: Need some Farmall 706 hydralic help!
Posted by Redman on May 15, 2004 at 07:25:44 from (66.44.173.170):
In Reply to: Need some Farmall 706 hydralic help! posted by LanceM on May 14, 2004 at 17:00:30:
pipe goes with the angle end into the housing.
i would guess the piece you found is off the 3pt/fast hitch linkage,if it will only work with the draft level that is where it came from.
their are 4 1/4" bolts on the right side of the seat paltform,take them out and you can see the linkage.
if it fell off or broke i wish you luck as they can be a real pain.
Post a Followup
: Re: Re: Need some Farmall 706 hydralic help!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
