Re: Re: Re: 966 clutch shaft
Posted by Spencer on May 15, 2004 at 18:45:44 from (64.179.7.247):
In Reply to: Re: Re: 966 clutch shaft posted by aaron on May 15, 2004 at 17:57:32:
i'm not talking about the throw out bearing. there is another bearing on the outer shaft which is called the iptoe shaft (i think thats how you spell it) and the cover you take off there is a seal on that and an o-ring. the way it sounds i'm pretty sure your going to need that bearing. with that seal just take a screw driver and pound on the out side ouf the seal and make it bend in and it will come right out for ya.
Spencer
Post a Followup
: Re: Re: Re: Re: 966 clutch shaft
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
