Re: Re: Re: Okay, I got the axle off, how does it
Posted by KEN PETERSON Pete on May 30, 2004 at 06:11:23 from (12.154.105.126):
In Reply to: Re: Re: Okay, I got the axle off, how does it go b posted by Pat Rivers-Bowerman on May 29, 2004 at 18:34:55:
When you pull the bull gear axle you'll have to take the small square plate off on the inside of the axle, then you'll see a bolt head, loosen it take it and thick washer out. Of course you'll have to remove the wheel and bearing cap on the outside. Then with someone on the outside helping, the axle will come out. If it is tight I use a brass drift on the inside to get it started. As it goes slide a rod "the drift if long enough" through from the inside to hold up the bull gear, then you should have no trouble when you go back with the axle. Of course you should likely change the oil anyway and that still requires dropping the pan, but at least you don't have to hold the parts up in there as you go back. One last thing make sure the tractor is supported securly.
Post a Followup
: Re: Re: Re: Re: Okay, I got the axle off, how does it
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
