Re: Where to start on Hydralics on 404?
Posted by J in Pa on June 05, 2004 at 17:13:58 from (24.154.96.166):
In Reply to: Where to start on Hydralics on 404? posted by BB on June 04, 2004 at 20:01:20:
BB after you change the filter, did you fill the canister that holds the filter with oil? this is needed to insure the pump doesnt run dry. also aids in re priming the hydraulic pump. also there should be a screen around the filter. most of the time they get cloged before the filter. clean it good or replace it.
good luck
J in Pa
Post a Followup
: Re: Re: Where to start on Hydralics on 404?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
