Re: Re: Re: Re: Carburetor float help!!
Posted by Zak on June 11, 2004 at 10:43:21 from (128.175.85.99):
In Reply to: Re: Re: Re: Carburetor float help!! posted by Bob M on June 11, 2004 at 09:29:32:
Great additions all! Now lemme add mine as I just went through this exact same problem last last week on my 300. Yer gonna haveta take yer carb off (again) to do this but...
Once the carb is off (I'm really good at this part having done it about a million times last week) check yer float for pinholes. Once you've done that, take out the main needle as well as the main metering tube (that long thingy sticking up out of the bowl and pointing down the carb bore. Put a drop or two of loctite on the threads of each of these items. Make sure you install the fiber washer with them as well. Let that loctite dry before putting the crab back together. This solved my problem completely as the gas was leaking past one or both of these threads. Also make sure your carb gasket is still in good shape after tinmkering with the carb so much. Mine had to be replaced (but I bought extras in anticipation of this problem). Good luck, you'll get 'er yet! -Z-
Post a Followup
: Re: Re: Re: Re: Re: Carburetor float help!!
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
