Re: Re: Re: Farmall 460 Transmission Question
Posted by lee on June 13, 2004 at 15:57:48 from (24.24.95.246):
In Reply to: Re: Re: Farmall 460 Transmission Question posted by Tony on June 13, 2004 at 15:18:17:
So it's no go at all when you have the engine running, select a gear and let out the clutch. Nothing happens. No noise, no nothing, not enev the slightest bit of drive? Will it slip into a gear from neutral with the clutch out? But if you try to tow it , it stops the truck, the rear wheels lock up? It's baffling. I don't have any section drawings of the 460 drive train. If I were going to tow a tractor to start it I'd probably use a high gear like 4th or higher. Not sure towing this machine is a good idea though. It's a planetary type TA on the fly, not a gear type hi/lo?
Post a Followup
: Re: Re: Re: Re: Farmall 460 Transmission Question
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
