Re: Magneto AND a coil
Posted by Bob on July 06, 2004 at 09:17:04 from (66.163.134.177):
In Reply to: Magneto AND a coil posted by Reido in MO on July 06, 2004 at 08:39:55:
The coil in the mag probably failed, or a PO just wanted battery ignition. You disconnect and/or remove the original coil inside the mag, and connect an external automotive type to the points inside the mag, usually also installing a condensor to match the original application of the replacement coil.
Since the original mag setup needed no external power supply, and the "kill" switch was used to short the primary side of the mag coil to ground to shut down the engine, the switch must be changed from a 1-wire ground-to-frame-when-off to a 2 terminal switch that is used to switch battery power to the new coil setup "ON" for run, "OFF" for stop, and a wire must be run from a source of battery voltage to the switch, and then the old mag "KILL" wire can be connected to the other terminal on the new switch, and the other end connected to the new coil.
Post a Followup
: Re: Re: Magneto AND a coil
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
