Re: farmall super a gas line
Posted by Hugh MacKay on July 11, 2004 at 02:32:33 from (216.208.58.186):
In Reply to: farmall super a gas line posted by bud sr on July 10, 2004 at 18:15:35:
Bud: Have run a few of these IH gassers in my time, like CNKS said air lock in glass bowl is about the only item you may have trouble with. My opinion if that doesn't cure it you must have a blockage from crud somewhere, stem into tank most likely.
Post a Followup
: Re: Re: farmall super a gas line
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
