Re: 504 Injection pump
Posted by Hugh MacKay on July 20, 2004 at 17:50:49 from (209.226.247.126):
In Reply to: 504 Injection pump posted by Jokke on July 20, 2004 at 06:40:47:
Jokke: This engine, I believe will have a Rossa Master pump. I'm no expert, but I have changed 5 Rossa Masters in my day without a manual and the all started first crack. I always lined up timimg marks on flywheel or front pulley at beginning. To be sure you are on right cycle remove small plate on the side of the pump and make sure timing marks in pump line up. From there just make sure nothing gets moved, and I don't thing you can put it together wrong. Be very careful putting shaft into a Rossa Master as there is an o ring within pump that seals around that shaft. End of shaft as you slide it in will take a piece out of o ring. Put lots of fuel on the shaft. If you damage the o ring diesel fuel will go by in and on to crankcase.
My experience was two 282 IH of which your engine is just 2/3, twice on John Deere 329, first time I damaged o ring. The 5th one was my Chevy 6.2 diesel. I also did them in that order so the o ring damage is not necessarily first timers. More a case of hurry.
Post a Followup
: Re: Re: 504 Injection pump
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
