460 question again.
Posted by Kelly C on August 01, 2004 at 16:49:17 from (63.171.43.140):
I got a chance to do a compresion test on my 460 today.
If you have been following my exploits with this 460. You know it runs like crap.
So far I have.
Cleaned the advance wheights in the dist.
Put new points and condencer.
New cap and rotor.
New plugs.
Timed it.
Rebuilt the carb. As best as I can.
Exhaust flapper thing seems to work. Heat riser I think its called.
That left me wondering if I had a burnt valve in the head.
Comp test revealed.
Cylinder #1 at 103 pounds
#2 at 103 pounds
#3 at 105 pounds
#4 at 104 pounds
#5 at 103 pounds
#6 at 103 pounds
Not sure if my tester is really all that accurate as far as highest reading its a cheapie.
But it does show that all the cylinders are about the same condition.
Wondering where to go now? By all rights this thing should be running like a top.
I am leaning to the carb again.
What say you?
Post a Followup
Subject:
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
