Re: No voltage at coil
Posted by john *.?-!.* cub owner on August 01, 2004 at 19:09:40 from (66.112.43.60):
In Reply to: Re: No voltage at coil posted by Terry on August 01, 2004 at 18:24:12:
Terry, Since it is a 12 volt system I assume the + side of the coil goes back to the keyswitch. I also am assuming it is a cub and not a cub cadet. Either you have a coil that is shorted , or a bad connection or faulty key switch. A shorted coil is unusual and should be causing the wiring to get hot. If you have a dropping resister (usually a long ceramic block with a terminal aon each end) to cut the battery voltage from 12 volts to 6 volts for the coil there is a good possibility it is faulty or has a coroded connection. Connect your coil and turn the switch on, then start working back toward the switch with your meter/test light.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
