Re: Still at the 460
Posted by lee on August 06, 2004 at 22:37:44 from (24.24.95.246):
In Reply to: Still at the 460 posted by Kelly C on August 06, 2004 at 20:24:55:
Does the carb have a high speed needle or fixed main jet? If it has a needle how is it currently set? Have you warmed the tractor and adjusted this new carb? Did the tractor come to you with the original carb? I assume the carb you bought is same as the one that came with the tractor when you bought it. Is it the correct carb for the tractor? I'm asking because I'm wondering if the carb is jetted correctly internal. I would be especially suspicious if it were a fixed jet carb. You've checked the compression and you say it starts and runs OK at idle. The timing is still a question in my mind even though you say it is timed I am not there to check it myself. This is mechanical advance only? No vac advance? How did you set timing? Did you use a timing light? Or did you do it static with a test light at the points? I would go all thru the ignition once again in terms of check points gap and timing. The timing spec is usually given with no advance. If you timed it with a light with engine running you want a very low speed to insure no advance is coming in from the mechanical advance. If you are using a timing light you should be able to see the advance come in if you watch the light and pick up the rpm. We've got to know the timing is really spot on and steady and the advance comes in as it should. You say pull the choke out and it runs. How far are you pulling the choke? Just a little? all the way? Something is amiss here because if I read your list of things done and believe in fact they are done correctly, the motor should be running and it's not.
Home
| Forums
Today's Featured Article -
A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
