Re: problems 560D
Posted by captaink on August 23, 2004 at 09:06:41 from (66.115.212.249):
In Reply to: problems 560D posted by Scotty on August 23, 2004 at 07:20:16:
Scotty, are you loosing anti-freeze from the cooling system, is it using any oil? How many hours do you have on the overhaul, and how was the engine broken in?
The 560 Diesel has dry sleeves, so the cracks in the sleeves are not where you were getting water in your oil, rather probably from the head. Another possibility is that the block may be cracked behind the dry sleeves, which could be a source of water in the oil.
How long are you holding your glow-plugs when you start the engine? Thirty to sixty seconds (is common), then continue to hold them and hit the starter. After it starts, hold the glow plugs in until the smoke clears or the engine starts to run smooth. Have you had the injector pump checked? The pump might not be putting enough pressure to the injectors under light loads to get a good spray pattern.
Good luck!
Post a Followup
Subject:
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
