Re: Farmall 400 Diesel won't move
Posted by El Toro on August 23, 2004 at 17:34:27 from (216.148.246.70):
In Reply to: Farmall 400 Diesel won't move posted by Braxton Fullerton on August 23, 2004 at 16:38:06:
Hi, Does the engine attempt to turn over? It may have a hydostatic lock due to coolant leakage
into the cylinders. I wouldn't pull it anymore until you check the engine to see if you can move it over by hand. The engine may be seized too since it hasn't been run in years. I would check that first. It may turn over hard, but you should
be able to rotate the engine. Good Luck, Hal
Post a Followup
Subject:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
