Farmall Tractors Discussion Board
Farmall C Surging Battery Discharge
Posted by Tony March on November 13, 1999 at 18:02:27 from (146.186.225.101):
I've replaced the surge control spring and adjusted the carbeurator linkage but engine surges when going downhill, it's ok on level and going uphill or when under a load. What is the problem?
I've converted to 12 volt, replaced the generator with a 1-wire GM alternator and 12 volt coil. The alternator charges ok but when left overnight the battery discharges. I have seen sparks on the alternator when i touched the fan and alternator with a screw driver--engine not running. What can I do to keep battery from discharging?
Post a Followup
: Re: Farmall C Surging Battery Discharge
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
