Re: 574 Parking Brake Cable
Posted by CEB on October 01, 2004 at 10:01:09 from (199.141.125.33):
In Reply to: 574 Parking Brake Cable posted by Ret on October 01, 2004 at 06:41:15:
The parking brake is actually a band that goes around a shaft inside the tranny. A cable hooks to the band and when you pull up on the lever it tightens the band around the shaft. You can adjust the cable, but if its already adjusted all the way, then you are going to need to replace the fiber band in the tranny. What happens is that operators forget to disengage the parking brake and run the tractor with it on, thus tearing up the band.
To remove the band, you will need remove the transmission top cover. this requires removing the seat assembly, 3 point arms from the back, and the fuel tank. You also have to loosen up at least one fender to get enough room to pull the fuel tank since the fenders bolt to the tank. There are several electrical connections and hydraulic lines that need to be disconnected also. The band is a pain to remove as there isn't much room to work in there. Overall, it can be done if you have some time and patience.
Post a Followup
Subject:
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
