Re: 560D head repair
Posted by captaink on October 29, 2004 at 08:03:44 from (66.115.214.56):
In Reply to: 560D head repair posted by SamC.VT on October 29, 2004 at 06:31:28:
This is from personal experience. When you get the head off, check the depth of the valve heads compared to the deck of the head. If they are not within spec, get the seats replaced and so they are back into spec. This will improve cold starting. The gasket mating surfaces of the block and head should be flat. I worked on a 460 once that was notorious for leaking water to the outside and I found a depression about the size of a nickel in the deck of the block. I decided to try JB weld (it had just come out) to fill it and it solved the problem. Depending on how it was starting and running before, you might want to consider having the injectors and injector pump checked. Were you loosing any water? If so, in addition to the head you will want to check the sleeves, etc. Oil consumption and blow-by should be considered as if either is excessive; you might want to do a complete rebuild if you use the tractor enough. Just some thoughts. I bought one about 22 years ago that wouldn’t start below +40 F without an M and a log chain in front. After I rebuilt and fixed valve seats, valve guides, put in new sleeves & pistons, worked injectors and pump, etc. The engine was back to spec and would start to at least -10 F without being plugged in. Found out the hard way one day when the block heater failed and it still started! Gotta love them when they do that! :>)
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
