Re: 656 Diesel Lifter Noise
Posted by Hugh MacKay on December 19, 2004 at 07:18:38 from (209.226.106.124):
In Reply to: 656 Diesel Lifter Noise posted by Bob in NY on December 18, 2004 at 03:26:29:
Bob: I can tell you 656 diesel will make quite a noise with a bent valve push rod. Don't ask why but it sounds far worse when your in front of tractor. I went to field to once to give message to my operator. Standing out front as he approached I thought the tractor was going to blow up. You could only notice it as a ticking sound from side or in operators seat. I called the dealer, he said check the push rods. Sure enough that was the problem.
Post a Followup
Subject:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
