Re: year-round cab 856
Posted by ny bill on January 04, 2005 at 19:58:42 from (66.24.196.252):
In Reply to: year-round cab 856 posted by 961powermaster on January 04, 2005 at 15:45:09:
i think the 66 series (which the hydro100 is one) has a wider frame than the 56 series. the difference that matters will be on the width of the clutch housing, as the back end of the cab will clamp to the axles regardless of the width. i had a 56 series cab on a 966, but it clamped only to the axle, so the clutch housing width wasn't an issue. there will be a small space above the hood if you can get the cab on the 856, as the 66 series has a little higher hood height. hth.
Post a Followup
Subject:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
