Re: question on my fast hitch on 230
Posted by shrps74 on January 13, 2005 at 05:52:17 from (64.12.117.13):
In Reply to: question on my fast hitch on 230 posted by Randy in Pa on January 12, 2005 at 19:57:39:
I have an "early" '57 230. You will notice that you do not have rockshafts on your hydraulic block. Super C's had options for adjustments to the 2pt via the rockshaft arms. 230's don't (at least mine doesn't). In order to get the plow to suck into the ground you will need to extend the arm that attaches to the front of the wishbone and then is now probably attached to the side of the torque tube (found on the "passenger side", as you put it). This will need to be changed to hook up with the attachment bolt holes (you will have 3) located at the forward end of the torque tube. The only one that will bolt it will be the bottom most hole. You will also have to take a pin out of the arm to extend it, then put the pin back in to hold it at this length. You will note that the arm will rotate 180 degrees to let you bolt this to the attachment bracket. All this does is to tilt the 2 pt so the plow points on a 2 pt plow toward the earth. I know this sounds complicated but once you look at the whole thing it will become somewhat intuitive. As said before, is your plow a 2pt (C-20) or a 3 pt? Hope this helps.....BobG in VA
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
