Re: About Allan's 3-point picture
Posted by Allan in NE on January 19, 2005 at 06:31:35 from (148.63.132.164):
In Reply to: About Allan's 3-point picture posted by williamf on January 19, 2005 at 06:16:16:
Hi Ya William,
Neither one. They are there to allow easy hookup to the implement.
When a guy is hooking up, you park the tractor "close" to the implement. You can then lift those "snatch blocks" and it will let the ball ends slide rearward another few inches.
They are spring loaded so that once the implement is 'hooked', ya just crawl back on the tractor and back up. The ball ends then will slide into the arms and the pull blocks snap closed.
They really work slick once you get the hang of using 'em. :>)
Have a good one,
Allan
third party image
Post a Followup
Subject:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
