Re: Help removing an H engine
Posted by Bob M on January 26, 2005 at 06:17:05 from (151.190.254.106):
In Reply to: Help removing an H engine posted by Slappy on January 26, 2005 at 04:25:28:
Here’s how I’ve done it: After the preliminaries (draining fluids, removing tinwork, wire harness, starter, radiator hoses, etc, and disconnecting fuel, oil, temp gage lines, air cleaner hose, etc) then… 1 – SAFETY FIRST! Securely chock both rear wheels against movement in both directions. 2 – Jack the tractor so the front wheels off the ground. Then securely crib/block under the clutch housing so the front end is cantilevered and supported at the clutch housing. 3 – Disconnect the steering shaft at the U joint. Loosen both frame rails at the clutch housing, then unbolt and remove the entire front end (bolster, front wheels and radiator) as a unit. Use your engine hoist for this – this assembly weights 600# or so and is TOP HEAVY! Set the front end aside - face down on a pallet is good. (Be careful not to bend or damage the steering shaft!) 4 – Unbolt and remove the side frame rails. The next several steps are best done with the aid of an assistant…. 5 – Position your engine hoist over the engine and draw it snug or a bit more. (But not so the clutch housing is lifted off the support blocking) 6 – Now remove the bolts that hold the engine to the clutch housing (including that bolt hidden ahead of the starter!) 7 – Finally lift and move the engine forward several inches until the clutch comes free of the splined tranny input shaft. You've now got the engine free of the tractor. Have fun, but don't sacrifice safety to save a few minutes or a couple of $$!
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
