Breaking engine free on 10-20
Posted by Mcoder on January 26, 2005 at 16:41:02 from (66.15.172.156):
Hi Folks,
Having never overhauled an engine before I have what is probably a stupid question. The engine is in a 1926 10-20 and is stuck, the top of the engine (rings, piston tops and sleeves) are very rusty, the bottom of the engine (crank, rods and caps) look good and are all lubed and shiny. I've removed the head, oil pan, fan assembly and have removed the split ring thereby disconnecting the clutch from the transmission. I've been soaking the cylinders in various fluids and penetrating oils for several months. So my question is this: Do I need any more disassembly before try to pound the pistons free? Do I need to remove the clutch, rod caps or governor housing? Any advice would be greatly appreciated.
Thank you.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
