update on F14 governor? maybe?
Posted by Doug Steinbach on March 10, 2009 at 16:29:47 from (71.154.9.106):
I borrowed a timing light with advance and double checked the timing. Per the specs in my shop manual which says magneto running timing is 35* B TDC, it is dead on the money. Always good to know, and it eliminates any doubt.
So back to the governor. I did some minor quick adjusting per the instructions in my manual and there was a small improvement. So I went a little deeper and set the governor the way the manual says. Borrowed some other fancy little gadget from my mechanic friend and we also set the RPM's according to the manual. Hooked up the truck via a tow strap, put the truck in neutral, held the brake slightly to put the tractor under a load, set the carb while pulling under load.........AND, the tractor I don't think ever ran as good as it seems to be right now.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
