Re: Newbie Cub owner
Posted by El Toro on February 23, 2005 at 18:40:03 from (205.188.117.13):
In Reply to: Newbie Cub owner posted by Newbie Cub owner in MA on February 23, 2005 at 13:44:38:
Check the point gap, should be set at .020". Use
a piece of 400 grit emery cloth to clean the points. Have someone crank over the engine with
the ignition switch on while you hold No1 plug
away from the sparkplug to see if you have a good
hot spark. Be sure tractor is out of gear.
If you have spark, remove No1 plug and shoot some gas into the cylinder, then replace plug and see if engine fires. If it does you're not getting
gas, check for fuel at carburetor. Could be gummed up from old gas. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
