Farmall Tractors Discussion Board
The Red...GM engine
Posted by ltf in nc on December 05, 1999 at 07:38:32 from (206.228.213.88):
If memory serves me, that engine you just got running has a mechanical fuel pump. Since the engine has not run in a long while there is a good chance the diaphram in the fuel pump is going to burst. If it does it will flood the crankcase with gas if insects have clogged the vent hole in the side of the pump. These pumps are cheap at auto discount stores, as compared to the source of the machine, and I would replace it. I would not expect any problem from the water pump as it has a face seal. Good luck
Post A Followup
: Re: The Red...GM engine
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
