Re: Installing a belt pulley on an A
Posted by Wayne Swenson on March 27, 2005 at 16:57:26 from (66.191.70.4):
In Reply to: Installing a belt pulley on an A posted by JR in TX on March 27, 2005 at 16:28:49:
Thoroughly clean the splines on the shaft. Use the flat surface of a file to smooth off the edges. Use the edge of the file to get into the grooves of the shaft.
Clean the inside of the pulley splines as best you can.
Be careful using a hammer to install because the bearing on the inside may become damaged with too much force. Grease the splines before installing.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
