Re: B414 Hydraulic flush
Posted by JB2 on March 29, 2005 at 21:46:41 from (24.157.143.220):
In Reply to: B414 Hydraulic flush posted by Eric Rylander on March 29, 2005 at 18:47:09:
Hi Eric, the filter is in the return line in the front of the reservoir under the seat. When you sit on the seat and look down at the top of the transmission cover between your legs on the right side you will see two steel hydraulic lines from the hydraulic pump to the reservoir. The small one is the pressure line and the large one is the return/suction line. The filter is on the end of the suction line in the reservoir.
To remove the filter without loosing Hytran fluid, park the tractor on a steep incline with front pointing up. Lock parking brake, turn engine off and put transmission in reverse gear LO range.
On the suction line, about 6 inches from the reservoir you will see a rubber sleeve with two hose clamps on it. Clean all the dirt from this area, loosen hose clamps and slide rubber sleeve forward on the suction line until the joint in the suction line is exposed. The suction line towards the reservoir has a slight curve to it, now rotate this section of the suction line until the curve allows this section to be clear of the section to the hydraulic pump. Now carefully pull the section in the reservoir towards the front of the tractor. Becareful to pull in a straight line as not to damage the filter screen that will come out of the reservoir.
Clean filter screen with solvent and dry. Put some lubricant on the "O" ring seal and re-install in reverse order.
Hope this helps. Can't remember Hytran capacity. The fluid can also be drained from the suction line by putting a piece of flexible hose on the suction line into a container. To drain the system you would not park the tractor on an incline.
Good Luck
JB2
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
