Re: Woodruff key on PTO
Posted by captaink on April 20, 2005 at 16:40:55 from (66.115.214.56):
In Reply to: Woodruff key on PTO posted by J.D. Palmer on April 20, 2005 at 16:03:23:
If the PTO gear does not fit snug on the shaft, this will lead to easier shearing off of the key. Unfortunately, the only way to correct a loose gear on a shaft is to replace the worn parts. You could try using a softer shear bolt to see if that will take some of the “jar” off the PTO when the shear bolt breaks. It’s tempting to take them to a machine shop and have the key cut out oversize. That might keep it from shearing off, but may cause damage to something else further into the drive line.
Maybe someone else here has some ideas…
Post a Followup
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
