Re: SA hydraulic problem
Posted by Mike@NY on May 04, 2005 at 01:16:46 from (24.58.224.75):
In Reply to: SA hydraulic problem posted by mchief on May 03, 2005 at 23:32:33:
My C was doing the same thing at one point. I belive the Hydraulic pump probably just needs new seals (rebuild kits are available, usually for your local Case/IH dealer), or, like my pump, there is an issue with the shaft in the pump, where there may be a bur on it or the hole is worn and a bushing is needed. I put a kit into mine, and it worked for about 2 weeks, then it all leaked out again. We determined there is an issue with the shaft on mine, just haven't gotten it fixed yet. I pulled the gear off the pump so I didn't burn up the pump and I can still get some use out of the tractor. I am sure others will jump in here as well. Hope this helps some. Good Luck.
Post a Followup
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
