Re: Head Gasket problems
Posted by MN Scott on May 08, 2005 at 20:18:56 from (206.9.216.75):
In Reply to: Head Gasket problems posted by Darin in Nebraska on May 08, 2005 at 19:51:51:
Did you coat your gasket with copper coat? You are supposed to. Have your head checked for warpage and cracks and have it resurfaced for a good sealing surface. Torque the head to 80 ft, Lbs. Then run it to get it warmed up and retorque it. It will have loosened up some. Good luck!
Post a Followup
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
