Re: Governor and loader
Posted by Bob M on June 01, 2005 at 05:06:56 from (151.190.254.107):
In Reply to: Governor and loader posted by Carlton on May 31, 2005 at 21:37:24:
Carlton - Low RPM is probably an adjustment problem in the linkage between the throttle handle and the governor. Try disconnecting the linkage at the governor input arm (the lever sticking up between the governor and the block). If you now can get full RPM’s by working the governor input arm by hand, readjust (lengthen) the linkage as required then reconnect.
If that doesn’t help, you’ll need to go inside the governor housing and look for an improperly adjusted high speed screw or possibly a weak governor spring.
The “right side low” problem with the loader says something is bent – probably a loader arm. Only fix is to straighten (or replace…) the bent parts.
Post a Followup
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
