Re: Farmall M runs and dies
Posted by RustyFarmall on June 13, 2005 at 15:37:58 from (199.120.81.220):
In Reply to: Re: Farmall M runs and dies posted by nositri on June 13, 2005 at 15:09:13:
A new needle and seat is not enough, you need to completely disassemble the carb and soak it in carb cleaner overnight. In other words, completely overhaul the carb. Would also be a good idea to inspect the gas tank on the inside, it might be full of rust and other crud. While you're at it, remove the sediment bowl assembly and clean it good. If you don't like what you see in the sediment bowl, replace it. A new assembly is under $30.
Post a Followup
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
