Re: 1945 Farmall H--bad generator?
Posted by captaink on June 23, 2005 at 07:49:57 from (66.115.214.56):
In Reply to: 1945 Farmall H--bad generator? posted by Kansas Kyle on June 22, 2005 at 18:43:17:
What you are describing could be two separate issues. The starter could be a bad switch on the starter and the dying could be from a coil or condenser that is going bad. The first thing I’d do is replace the condenser and take a look at the starting switch. A lot of times the contacts in the switch get pitted or “burned” and won’t make good contact. Now, come to thing about it when you say “push button” could this have a solenoid in the starting circuit? If so that could be going bad and not powering the starter properly. I have also tested starters by hooking up jumper cables directly to the starter from a 12-volt system. If the starter rolls good then, likely it is in the wiring (including switch or solenoid) between the battery and the starter.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
