SUPER C idle too rich
Posted by JOWENS on July 06, 2005 at 10:10:49 from (63.158.168.41):
My super C has a problem that I can't work out. It runs rich and fouls plugs at low to mid range rpm. I use it to mow with and it has plenty of power and runs smooth with new plugs at full throttle while mowing, so I don't believe it is in the ignition. Which is still 6v, every thing is new except the coil. letting it idle for more than 5 minutes will foul a set of plugs. the carb is a zenieth, not sure which model. but it only has an idle adjustment. Initially the adjustment made very liitle difference wether it is tight or loose. I assuned the port was plugged so I rebuilt the carb and cleaned the ports and checked the float level and still the same thing. Next I lowered the float level alomst an 1/8 still the same. Next I ran a .02 larger drill bit through the idle jet wich seemed to make a difference in the screw adjustment, but it still fouls plugs. While it running i can pull the idle screw out and it will make very little difference on how the tractor runs although you can here it sucking air. I've had the tractor around a year and it's been doing the same since i bought it. I don't know the history behind the carb on the tractor. Any help would be greatly apreciated.
Post a Followup
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
