More On Fuel Injection on IH Sixes
Posted by Buzzman72 on September 08, 2005 at 07:59:16 from (4.89.133.97):
One of the requirements on most fuel injection setups is some sort of electronic ignition. While Pertronix is what most tractor folks go to, since the only difference between the IH tractor six distributor and the IH truck six (SD, BD, and BG 220/221, 240/241, and 264/265) is the lack of a tach drive and the addition of an EXTERMAL vacuum advance on the truck motors...a GM HEI off a Chevy six can be adapted to work on the IH six. It requires removing the distributor drive gear; shortening the shaft and slotting the end of it; installing a bronze bushing--available in the hardware section at Tractor Supply as Hillman 1/2"x5/8"x1-1/8" [will also have to be shortened]--to keep the distributor and oil pump connected; grooving the distributor housing for an O-ring; and, since the IH engines rotate the distributor the opposite direction from the Chevys, rewoking the centrifugal advance. And if you want the vacuum advance to work, it requires a vacuum advance from an Olds [they turn opposite direction from Chevy], and some reworking of the housing to make it fit [think hacksaw, grinder, and some J-B Weld to fill the space where the old vacuum advance entered the distributor housing]. On the JustInternationals website-- www.justinternationals.org --they diagram SOME of the distributor mods, and make it look fairly easy. And since they are at the forefront in fuel injection conversions for International V8's, there may be some "trickle-down" from their discussions that can be applied to the sixes as well.
Home
| Forums
Today's Featured Article -
Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
