Re: Leaking 1066 Injector
Posted by K.B.-826 on September 26, 2005 at 19:14:07 from (68.115.103.185):
In Reply to: Leaking 1066 Injector posted by Pete in Tejas on September 26, 2005 at 13:47:22:
Pete, try a new line before replacing the injector. I"ve had the same thing happen many times, 99% of the time the line is cracked. Replacing an injector on a 1066 is a pretty tough job if you"re out in the middle of nowhere and never done it before. There"s a good possiblity that the injector will be stuck, and the cooling sleeve may come out with it. Gotta drain the cooling system in case that happens, or you dump the coolant into the cylinder. Even if you get the injector out with no problem, you still need to get down in there and clean up the bore and the seat perfect, or the new injector will not seal. There"s also a copper sealing ring that needs to be replaced. Call a different Case-IH dealer, most will be more than happy to UPS parts.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
